hid's where to buy from?
I bought mine on the classifieds board but you can get them from http://www.ledgauges.com/.
They're very easy to install... took maybe 30 mins total and most of that was from jacking up the front of the car and unscrewing the bottom of the front bumper.
Copy & Paste Moderator
hids in a non-hid housing like the non-sealed beam housings some places sell for our cars. It causes massive amounts of glare and usually doesn't light up the road all that well for you to see. Hella makes sealed projectors that you can mount with ease in our cars that are a decent price that you could throw HIDs into.
go to google and type in Hella 90mm projectors and go to the website that has rally and lights followed by a .com There are three different types you can go with: The 90mm H9 which is mainly for use with halogen bulbs but some aftermarket HID companies make a rebased H9 bulb so you could do that. With the H9 projector there is also a way to modify it to fit a D2S (the most common OEM HID bulb) in there.
There is then the 90mm H7 ECE code projector. A little more expensive but a better cutoff and easier to modify to fit in the D2S bulb. All you have to do is purchase a H7 to D2S adapter on ebay for like 7-10 bucks.
Then there is the 90m D2S projector. It'll be expensive for a set but in my opinion it's worth it because it is made to fit the D2S bulb, you won't have to worry about weather getting into the projecter either because it seals up pretty well. I have this and they are cool I just have not yet installed them on my car becaue i want to wait until i rip the car apart to paint and re-do the interior so I make sure I get it right. They seem like they will be easy to install.
You could also try and retrofit a non-sealed projector in there but that is more time consuming and most likely going to be more money. I tried doing that with Bosch e46 projectors on my LT1 but I didn't have the funding or time to fool around with it. If you end up getting all the stuff i'll help you install it and make a wiring harness for it. Because our factory harness sucks *** and will not perform all that great with something like HIDs. (as I found out with the fog light hids on my last car).
Hopefully I don't get yelled at for that since none of the sponsors carry anything like it.
DirtyBird222: If you want, you can put together a write-up or information post and I can add it to the Lighting FAQ. You seem to know a lot about the subject.
VIP if you want, I've just researched it so much due to the lack of options we have as firebird owners in what we can do as far as aftermarket performance lighting.
I have yet to fix my problem with my new car, but on the LT1 bird i had both lights would start up and work fine for a few minutes but the passenger side would start to flicker/blink. I thought it might have been the ballast/bulb but I switched sides and the same side did the same thing. So I cut cut the bulb off a stock 880 and used that as the starting point for harness. Soldered some heavy gage wireing onto the base of the old bulb and ran it to the ballasts and everything worked fine. For some reason I couldn't solder the 880 bulbs that were in the car and haven't tried anything yet on the LS1 car. When not bolted in both lights come on and stay on, but when I install them onto the car only the drivers side works. I have switched sides and everything and same problem. It could just be the kit I got from ledgauges but I just wanted some for the foglights like that, I'm going all OEM for my headlights!
Was the metal casing of the ballast touching metal on the car (like the frame)? Many people have reported that isolating the metal casing from the frame fixed the issue. I guess it may have had a ground loop problem.
It is touching the frame but I have no idea where else to put it, the other ballast is on the frame too. The LT1 was easier because I just mounted the ballasts at the bottom of the fog light bracket, on the ls1s they are a little different and I can't do that. I'm thinking I have a ground problem but I don't know where to even start on that.
Use double sided foam trim tape to put a sheet of plastic between the ballast and frame. Then augment that mounting with zip ties. The plastic sheet will keep the ballast off the frame and the foam tape will hold the sheet to the frame and ballast to the sheet. The zip ties are extra insurance to make sure nothing moves.
-or-
Use high-strength auto/outdoor velcro to attach the ballasts to the frame (cover the whole bottom of the ballast so none of it can touch the frame).
I'll probably go with option 2.
I have used high-strength auto/outdoor velcro on other areas with luck.
Make sure the area is clean before doing either.
-or-
Sounds like they are grounding to the frame. Double sided tape or velco will fix that.
Also if you plan on getting HID's for the fog lights it might help to run a relay as well.
