Aftermarket screw on Antennaes
You can cut yours. Heard you can cut it in half, or in quarters (try and keep it as close to 1/2, 1/4, 1/8, as you can, not some weird 1/358 or whatever). Then glue the little ball end back on the shortened part.
I'm considering doing this with mine. Free mods are best when flat broke
do a search for bitviper. He is a sponsor on here and sells a lot of antenna's that he had modified. They look bad ***. would have one if i did not have the power one on my car
ryan1428..check your PM's
Your options are....in no significant order....the obviousl best choice
Then
1. Cutting the stocker..just make sure to cut it in a multiple of its full length abd then glue you ball back on the top
2. Ecklers
3. PFYC I believe sells a "Shortie Corvette Antenna" which is exactly like #1
4. Autozone sells a floppy one..
5. Go electric..and get one that retrracts
Id stay away from the ultra short one piece antennas as they are just for looks..
