How to get the "trans am" lettering off the rear
Well you may not fully understand the construction of the rear center section panel then.
It's not a decal on the center section. It's an embossed ink stamp.
If it fades out, you CAN simply place a decal over it, if you get the matching decal.
If he uses a towel & some type of product to remove the ink, the embossed area will still be visible. Then simply adhere the decal.
Or wet-sand to completely remove it all together, ...
(<--- See feedback, ..., I've done this a couple hundred times, ...)
I just completely blacked mine out... the bird is embossed in so i used 400grit, 600grit, 800grit, 1000grit, 1000grit wet, 2000grit, 2000grit wet, polishing compound, then plastic lens cleaner/polisher in this exact order and it looks like it came from the factory that way...not to mention it looks cleaner without the bird(that doesnt really flow with the car too well)...
