Re opening Headlights
Old 11-25-2007, 11:58 AM
crapyboy750's Avatar
Default Re opening Headlights
I did the whislter mod about 3 weeks ago and now my headlights are kinda hazy. But the sealant that i used with stands 500 degrees so how do i go about re- opening the headlights? Would i just be able to use a razor blade to cut the sealant or what?
Old 11-25-2007, 12:32 PM
Brian2006's Avatar
Put them in the oven at 200 degrees for 25 minutes. If you try and use a knife you'll just break bits off the headlight without heating the sealant.
Old 11-25-2007, 12:35 PM
OK so just do it the same way as i did when i did the whistler mod?
Old 11-25-2007, 12:41 PM
Brian2006's Avatar
Yep. I've done this a number of times even after I already did the whistler mod
Old 11-25-2007, 01:13 PM
OK thanks man
Old 11-25-2007, 06:13 PM
Havok2's Avatar
just dont put the oven at 350
Quick Reply: Re opening Headlights
