Sponsored by: DashLynx
Cleaning Leather Interior
Old 12-05-2007, 11:21 AM
SLOW30th-TA's Avatar
Default Cleaning Leather Interior
Hey Guys. I have a 30th Anniv. TA and need a great leather cleaner bc the interior is white. Any suggestions will be helpful.
Old 12-05-2007, 12:43 PM
Gipraw's Avatar
Meguiars Gold Class Rich Leather Aloe Cleaner and Meguiars Gold Class Rich Leather Aloe Conditioner. very good two step product that will work well, with no chance of harming your leather.
Lexxol makes a decnt cleaner also.
Old 12-05-2007, 12:49 PM
DANSBIRD's Avatar
Yes... trade me your interrior... problem solved
(ive always wanted/LOVED the 30thAE interrior)
Old 12-05-2007, 12:51 PM
DANSBIRD's Avatar
I agree... I've never tried the Maguiers, but i really like the Lexxol. It makes the leather very soft, i am just not too fond of the scent.
Old 12-05-2007, 08:14 PM
wannafbody's Avatar
Zaino Z9 or Z10
You can also make your own cleaner with 1 part Woolite to 6 parts water. Mothers leather stuff is good OTC stuff.
Old 12-06-2007, 10:18 AM
ArcticZ28's Avatar
Mild soap and water.
Old 12-06-2007, 12:06 PM
30birdy99's Avatar
As a long time 30th owner I would caution you on using ANY solvent or chemical. The white will come off or be discolored permanently. Saddle soap and warm water will clean, revitalize and provide that striking bright white appearance again.
Old 12-06-2007, 02:09 PM
7901 WS6's Avatar
My 25th needs a good cleaning. Where do you get saddle soap from?? Does it condition the Leahter too or just Clean??
thanks
Old 12-06-2007, 05:12 PM
LS1TECH Sponsor
Steve P's Avatar
Tropi-Care TC-10 Leather/Vinyl/Fabric Cleaner $7.95
Deep cleans these surfaces without removing natural oils. As a bonus, it can also be used for removing imbedded dirt and grime in carpeting.
Tropi-Care TC-11 Leather Conditioner $10.95
Moisturizes these surfaces and preserves the natural oils which may be lost due to heat, sun everyday use and age.
Be sure to check out our TCB-30 Upholstery Brush just $3.95. Excellent for use to clean carpets and fabrics.
Orders over $30.00 get FREE shipping through 12/31. See these and more at www.tropi-care.com
Old 12-07-2007, 11:49 AM
30birdy99's Avatar
"My 25th needs a good cleaning. Where do you get saddle soap from?? Does it condition the Leahter too or just Clean??"
Any Walmart or shoe store should have it for about 2 bucks a can. Apply with warm water and a very clean, preferrably white cloth. Just to set the record straight, GM didn't use real leather on their seat material. But yes, it does condition as it is applied.
Old 12-07-2007, 04:30 PM
TARaptor's Avatar
I have fully cleaned a 30th interior and what i did was use a mild soap and water solution with a soft brush, a trick use the brush on your arm and feel how hard to scrub that so it doesn't hurt but you are applying some pressure, work the leather in small areas wiping up the moisture right after you scrub so the dirt cant settle back in, i was amazed how much dirt was on the white towel i used. Then i used lexxol per the instructions on it, the seat came out brighter and softer than i had ever felt them.
Old 12-08-2007, 09:25 PM
ArcticZ28's Avatar
Pretty much how you should do it, to the T. Brush it softly, immediately wipe up excess, let it dry for a couple hours or even a day, then condition.
