camaro custom gauge pods....
Old 12-15-2007, 09:53 PM
Havok2's Avatar
Default camaro custom gauge pods....
ok, not in the cubby hole by the shifter, not in the ashtray.
t/as are lucky, they can put the gauges in the ac vents
where else can i mount them? (i know about the pillar pod)
something little diff....
ac vent done by anyone?
Old 12-15-2007, 10:00 PM
phantomzer0's Avatar
You can buy a trim piece to put a gauge or 2 in your Vents. I'm not sure which sponsor sells it but I know they do. Theres a few pictures floating around.
Old 12-15-2007, 10:10 PM
Brian2006's Avatar
and the guy that molded a single gauge/pod in his kicker panel
Old 12-16-2007, 12:41 AM
Havok2's Avatar
i saw that molded one, but i think its too low. not very user friendly. i want it easy to glance at..not look down then BOOM, crash into car in front of me...
Old 12-16-2007, 10:33 AM
RIDINFILTHY's Avatar
i put my trans temp gauge in my ac vent looks pretty good i just fabbed up a piece of aluminum and stuck it in!!!!!!!!!!!!!
Old 12-16-2007, 03:48 PM
Havok2's Avatar
yeah? show me a pic, thats what i have in mind.
Old 12-16-2007, 04:04 PM
RiskyZ28's Avatar
mine is a track car so the radio area was blocked off and i have 5 gauges in the old radio hole
Old 12-16-2007, 08:41 PM
618HAWK's Avatar
Its not in a Camaro but would fit. Fabbed this up a while back. Mounts with a stock radio mounts screw and a dash pad screw just inside the glove box door. Still gives plenty of clearance for the cup holder and air bag deployment.
Old 12-16-2007, 10:36 PM
Mean Green z28's Avatar
Here's what I did for a customer... click for larger pic.
Old 12-17-2007, 12:48 PM
Havok2's Avatar
MeanGreen: i think thats something what i want. but paint the alum black.
Old 12-17-2007, 05:13 PM
6LITEREATER's Avatar
Well, since the roof is about the only place you did NOT name ...
Try this, get a Mustang pod:
and mount it on your dash (on top of the center air vents basically). With a little trimming it will sit flush. I've seen it on here before but can't find the pic now...
Or use this Mustang one:
and make it fit your steering wheel (might be easier to just use an a-pillar pod on there though).
Old 12-17-2007, 07:37 PM
FireSilverLullaby's Avatar
yeah i think mean greens would look really good, especially in black. subscribing
Old 12-17-2007, 07:53 PM
Thanks guys for the comments on the vent pod. I didn't even know people have done this when I did this. That was over 2 years ago. It's after I did it that I searched on here and saw that many were talking about it. The customer already had three gauges on a pod, and Camaros aren't blessed with the T/A style dash center vents, so this was the next logical place. All it is is a sheet of aluminum bent on both sides and it clips onto the vent tabs. Took some time to get it shaped and cleaned up ('cos I didn't have a sheet metal break at my disposal so it's all hammering and sanding, but I think it was worth it. I was also lucky that the it wasn't a larger dia. gauge housing. A larger dia. housing wouldn't have let us do this 'cos it wouldn't leave enough room above and below the vent to make the pod one single piece and I didn't want to modify the vent housing just in case he wanted to return it to stock. So take note when ordering your gages and use a smaller gage that's not as important as the others you'll have at eye level. Here's a couple more I've played around with ...
In a C5 drag car...
3rd gen Camaro...
Old 12-17-2007, 08:25 PM
Reject's Avatar
love the corvette setup
Old 12-18-2007, 10:31 PM
Snuffles's Avatar
I started working on something last February and worked on and off for a while.
It has come a long way but still has some imperfections, as you will see in the pics.
Here's what I've been working on:
(I tried to angle the light to emphasize what needs to be fixed.)
This is only my second time working with fiberglass. I used online how-to's to help me out.
Input is greatly appreciated.
Old 12-18-2007, 10:44 PM
Numba1Stunna's Avatar
that would look great, i wish i had some tips to help. if someone sold something like that i would be all over it
Old 12-18-2007, 11:19 PM
Brian2006's Avatar
Holy hell that looks absolutely incredible
Old 12-18-2007, 11:24 PM
Havok2's Avatar
you snuffles can i see a pic from behind?
how did you move the vent to the middle??
Old 12-18-2007, 11:38 PM
Snuffles's Avatar
Thank you, sir.
Sure. Once I take one.
It took tons of fiberglass work to move it to the mid.
There's a lot of hours into this piece.
I've completely redone it 3 times.
Old 12-19-2007, 12:02 AM
Brian2006's Avatar
Thank you, sir.
It doesn't even look like you used fiberglass. Looks stock
Quick Reply: camaro custom gauge pods....
