turn signals
turn signals
i got some new black turn signals for christmas and i was just wondering how hard they are to put in and what all is involved in doing that. any tips? suggestions? or even a write up of how to install them. thanks to anyone who helps me out.
Headlights come on with 1 bolt... Its eaither 7 or 8mm... When you take out the bolt you slide the headlights towards the center of the car and they will fall out. Then the turn signals are right there and are held nin by 3 small bolts...
headlights take about 30 seconds each to take out. I believe its a 9mm bolt. Then the turn signals are held on by 2 7mm bolts on the side and one on the bottom. To get them out I trimmed the foam around them and pulled them out and put the new ones in. I had about 30 mins into the whole project from start to finish.
