SS lines for radiator hose
has anyone done this? what size line would i need and what kind of fittings would i need to clamp the line to the radiator and water pump?
do you mean steel braided or stainless steel??
its not under a lot of pressure so you could use a normal band clamp. i did this for my heater hoses used -10 braided line not sure what size you would use for raidiator lines its like an 1inch or inch and 1/2 so thats a place to start look at some hot rod mags and you may find something like you are wanting
