replacing rubber molding outside of driver window
how do you do it, i took mine off to replace a broken window and it went back on but is all loose. does any one know how to tighten it thanks
jay
jay
Re: replacing rubber molding outside of driver window
Try some weather strip adhesive from you local Autozone, Pepboys, etc. Pull the trim off, clean the door portion and the back of the weather strip with some adhesive remover, apply the weatherstrip adhesive and re-seat it.
