My Whislter mod pix
Remove headlights
Remove 4 clips on the headlights
Warm up your oven to 200 degrees
Put one light in at a time for 15 minutes
Use thin flat head screw driver to seperate the lens from the body, by working it around the lens. Then pull is apart.
Repeat for other headlight.
Mask off the areas not to be painted.
Scuff the areas you want to paint/use 1500 or 2000 grit.
Paint with your color of choice, black is most guys opinion is the best...others have done white, red, etc...
Reinstall lights.
Then sand the light only the part to be painted, tape off the inside of the light like the guy has pictured up there ^^
Just put some new sealant on the light, and put the metal clips back on.
Oh, and only one 1/2" bolt holds each headlight.
That looks awesome!!! I wanna do mine but im scared that when i mask off the inside, the mirror finish will stick to the tape. I saw someone do that and had to buy new headlight housings.
