Sponsored by: DashLynx
Vette lettering removal on FRC HELP!
Old 03-24-2008, 11:06 PM
01SOMSS!'s Avatar
Default Vette lettering removal on FRC HELP!
how hard is it to remove the corvette lettering in the FRC's? is there a write up? thanks!
Old 03-25-2008, 12:02 AM
Brian2006's Avatar
It's painted
Old 03-25-2008, 12:09 AM
irbs's Avatar
Fill them in with some type of filler.
Old 03-25-2008, 12:42 AM
fast01z28's Avatar
I used my dremel to scuff up the paint, then I filled it with "kitty hair" which is a very hard mixture of bondo and fiberglass. I then sanded it down, and used body filler to fine tune it and make it perfect.
its not hard, but can be time consuming depending on how perfect you want it, and how much patience you have.
Old 03-25-2008, 09:29 AM
01SOMSS!'s Avatar
is there a write up on cutting it to fit an fbody?
Old 03-25-2008, 09:32 AM
fast01z28's Avatar
I dont know of a write up, but if you go to my sounddomain page and go onto the projects page youll see lots of pics from when i did mine.
i took this pic to give an idea of what to cut. I cut mine based on pictures i saw online. Of course i trimmed more where needed once i test fit.
Quick Reply: Vette lettering removal on FRC HELP!
