its a longshot...
Old 03-26-2008, 03:50 PM
fireman's Avatar
Default its a longshot...
..but, has anyone put Nissan 350Z seats in an Fbody?
I have some badass, black leather, full power seats out of an '06 350Z "track" model. Mounting points are way off but they will physically fit.
Just wondering if this has been done.
Old 03-26-2008, 03:52 PM
RickyMartinZ28's Avatar
Throw up some pics. I'd like to see those. Fabrication is usually not rocket science.
-Rick
Old 03-26-2008, 04:00 PM
fireman's Avatar
they look like these-
Old 03-26-2008, 04:01 PM
02gtp4now's Avatar
red x
Old 03-26-2008, 04:18 PM
Schantin's Avatar
Sure it hasn't been done, but if they physically fit, then it should be fairly easy
You can make adapter mounts to attach the seat to the stock floor mount points with 1/2" barstock steel (can buy that at Home Depot or similiar). If you can weld...then it's too easy. If not, cut the steel w/ a dremel, bend it/ w a vise to the proper shape, and then take the pieces to a local exhaust shop or garage to be welded. Should cost under $100 for both front brackets to get done.
As for wiring, you'll need both the wiring diagrams for the 350Z and the Camaro seats. You should be able to match the wires from that. Use the power seat connector from the old Camaro seats and adapt them to the 350Z seats. Then you can plug it into the car like factory.
Good luck. Should look pretty slick if you do it right
Old 03-26-2008, 05:54 PM
mycamaroSS's Avatar
yea my bro has a z and those seats are real nice, but he has the vinyl ones because he said the leather ones are a bit "slippery"
Old 03-26-2008, 06:50 PM
jsteele90's Avatar
sounds like a good mod bc my cloth seats in my z suck ***
Old 03-26-2008, 09:04 PM
Navy01Z's Avatar
The 350Z seats hug really nice but aren't too stiff. I hope you do it and post some pics.
