help w/ slp grille install?
im going to install my slp grille in about two weeks. there probably is a thread somewhere on here already about this but i couldnt find one! i have a lot of questions on how i should do it so i need your guys help. is there anywhere that i can find a step by step instruction on how to do this? also how should i take off the front fascia? is there anything i should careful of when taking off the front? i have been hearing alot about filling the holes or not filling the holes. is it bad to not fill the holes? if i decided to fill the holes what should i fill it with? also i heard that you can use 3M double sided tape to put the new grille in, is this a good idea, will the tape hold up?
the black camaro grille just pulls out. mark and drill the holes for the SLP grille and use the fastners to hold it on. you can also use the double sided tape for extra support. its very easy
