What bulbs fit in stock 99 T/A housing (HID mod)
im looking to buy an HID kit and either buying the eurolamps conversion or removing the old bulbs from my stock headlights. does anyone know if an H4 bulb will work with the stock headlight or do i need an H7 or 9006??? i have a spare H4 HID kit here but im not sure if they will work with the stock housing.
will post pics up of everything when its all done
yes but i was reading that you can remove the stock bulb and replace it with something else. what im not sure of is if you can fit an H4 bulb in and work properly or if you need H7, 9006, or such....
up!
any help appreciated
up!
Here's a writeup on doing it to a camaro sealed beam light. But the process would be the same for you:
http://performanceworks1.com/headlightmod.htm
You can find more links and info in the Lighting FAQ:
https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
