Headlight Bulbs
Copy & Paste Moderator
Check out the Lighting FAQ:
https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
Basically your options are conversion housings or projectors. You can buy conversion housings or make your own. Projectors would be a custom install. In both options, you can install HID, but I would suggest using projectors and avoid reflector housings (you'll usually get a bad beam pattern and glare using a reflector housing).
There have been some recent threads on this too. A search will yield plenty.
Here are some threads to get you started:
https://ls1tech.com/forums/showpost....58&postcount=5
https://ls1tech.com/forums/appearance-detailing/798344-02-firebird-headlight-signal-light-upgrade-questions.html
https://ls1tech.com/forums/appearance-detailing/740352-t-bosche-housings-5000k-hid.html
https://ls1tech.com/forums/appearance-detailing/844701-headlights-1000000th-time.html
https://ls1tech.com/forums/showpost....9&postcount=10
https://ls1tech.com/forums/appearance-detailing/837019-installed-new-hid-conversion-head-lamps-pictures-inside.html
https://ls1tech.com/forums/appearance-detailing/820206-t-seamed-beam-conversion-silverstars.html
https://ls1tech.com/forums/wiring-stereo-electronics/632913-brighter-headlights-firebird.html
https://ls1tech.com/forums/appearance-detailing/816975-true-projector-style-headlamps-98-02-tran-am.html
