Photos - Custom 35th SS LE grille
Finally got a chance to install my "custom" SLP 35th SS LE grille. Its "custom" because I blacked out the center section with some flat black vinyl decal material. In order to do so, I had to make patterns for the upper and lower decal out of paper first, then use those patterns to trace onto the vinyl before cutting them out. I actually had to do this two times each to get them to look/fit right.
Here is how it looked when I bought it:
Here is how a normal 35th LE grille looks:
Here is how mine looks now:
Clear Corners Installed:
more photos:
http://users.ev1.net/~ynot_dv8/02Camaro/grille01.jpg
http://users.ev1.net/~ynot_dv8/02Camaro/grille03.jpg
http://users.ev1.net/~ynot_dv8/02Camaro/grille04.jpg
Me so happee!
Tony
more photos:
Me so happee!
Tony
Re: Photos - Custom 35th SS LE grille
Hey, that looks killer, honestly. Wow, I'm usually not a fan of changing up factory looks (cause they are so good for the most part) but this is awesome.
9 Second Club NA
Looks good, but I think ya should have went all the way around with the black vinyl, not just the front.
Sorry Tony, I just dont like it. It looks weird and I cant decide why. Then again wonder what it would look like on mine.....
The clear corners look clean!
MadIce, I'm considering doing the sides also. I couldn't make the decals one-piece and fit those curves though, I tried. I would just have to make some small parts to cover the sides now if I decide to. I'm on the fence on that.
I'm just glad the big black catfish mouth (stock grille) is GONE. Those things are horrible.
Tony
Tony
I agree with MadIce, it still looks photoshopped since the silver is showing from the sides. I like the concept though. Now be prepared, Nineball has dished out this line many, many times but he has yet to recieve yet.....
"Now drop that 4x4!" :p
You get em!
Tony......looks awesome. Yet...another vote for finishing the sides as well. Still looks awesome, especially with the clear corners.
Paul
This car will be lowered soon! Going with the Hotchkis springs. :p
I also have some black Grand Sport wheels being delivered next week from AFS
Tony
Tony
Customizing Director
Tony - Yes it is pretty hard to have the vinyl bend 90 degree's without it creating a wrinkle. Three peices will be fine but then you will see a slight line where the ends meet. I personally think you should go ahead and paint it a flat black all the way around (if you plan to keep it), as long as you mask everything else off good and prep the area your painting a little bit you'll be able to paint it yourself
