Removing rear seat
Removing rear seat
I am planning on taking out my rear seats in my Camaro. Once I take out the bottoms, how do I get out the top part? Do I have to take out the Torx nut or whatever it is, or does the nut under that allow the seat to come out? Also, how do I get the seat belts out?
Thanx.
Thanx.
Re: Removing rear seat
You have to take the nut off of the bottom of the back part of the seat. They are 13mm. There is one on each side. Then you have to take out the 2 screws that hold each seatbelt guide in. Then the seal will just lift out. If you plan on taking the cover off, like I did, be warned that the torx bolts that hold the latches you pull to recline the back seat are tight. I ruined two bits on one of them and finally had to use a dremel tool to make room to get a wrench on both sides of it. But, the removal of the back seat is easy.
I hope that this helped.
