Sponsored by: DashLynx
Engine bay wash
Old 06-29-2008, 04:58 PM
jonssz28's Avatar
Default Engine bay wash
Is it a good idea to wash the engine bay of my car with the pressure washer that I own ? I have alot of dust build up all around the engine bay. Would it be smart to do a quick wash or a hand detail that would take hours, what is the best and easy way ?
Old 06-29-2008, 05:07 PM
98boxer's Avatar
I've never washed my engine bay so i can't give you advice on a how to. But i have read here that a pressure washer to clean the engine bay is not a good idea. There is a sticky here check that thread.
Old 06-29-2008, 05:11 PM
aothepresident's Avatar
You'll end up breaking something
Old 06-29-2008, 06:42 PM
2001CamaroGuy's Avatar
Depending on the pressure, be careful as some pressure washers can do 1000psi or more. I always pressure washed my camaro (still pressure wash my silverado) engine compartment, but this is at a self service car wash which is not "that" high of pressure.
Old 06-29-2008, 06:46 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Engine Degreaser/SIMPLE GREEN ...and a slow hose works best/safest.
Old 06-30-2008, 11:04 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
+1, I use either gunk or simple green, both work very well. rinsing with a regular hose is fine, and the pressure washers at the DIY wash places aren't too high pressure, just be mindfull while blasting..
Wade
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 06-30-2008, 02:45 PM
JBIRD02's Avatar
dawn dish soap and garden hose has always worked well for me
Old 06-30-2008, 03:38 PM
Firebird Phoenix's Avatar
When I pressure wash mine it is at the car wash. I don't pull on the handle and let it just barely spray out on its on with the engine cleaner. Then in the meantime I usually soak the wheels (as around here the car wash calls it engine degreaser/wheel cleaner). Keep in mind the whole time I have my car running, I figure if any degreaser or water is going to get in any place bad the heat will evaporate it *shrug*. Anyways to rinse it off I stand back as far as possible and spray with water, from the front & sides. This usually cleans it off just fine.
Like everyone else said the car washes usually don't have insane pressure like a home one.
Edit to add...i'd personally like to hand detail my engine bay for hours then just maintain it with rinsing it like I said above as its not ever perfect.
Old 06-30-2008, 04:27 PM
Ruckus46Gt's Avatar
i used a reg car wash hose , and a mixture of carsoap, and dawn power dissolve, diluted with water. Run the car for a min or two to heat it a little so the gunk will come off easier (do not shoot the water onto a hot engine bay). Once you get the engine bay clean its easy to maintain
Old 06-30-2008, 04:41 PM
billyb's Avatar
time and elbow grease, 4-6 hrs the first time then you'll see more areas patience ,
Quick Reply: Engine bay wash
