Sponsored by: DashLynx
Corvette Sport Seats
Old 11-22-2001, 04:24 AM
CJP63's Avatar
Default Corvette Sport Seats
Will the C5 sport seats fit in a 2000 SS camaro?
Old 11-22-2001, 07:33 AM
c4c5specialist's Avatar
Default Re: Corvette Sport Seats
HI there,
You can make them fit on the drivers side, with some slight modification to the seat frame, on the sport seat for the c5.
The passenger side is almost impossible, without some heavy fabrication work, due to the hump in the floor pan.
As far as the electronics, this is the tough part, as the seat control module will look for communications from other modules, like on c5. This was a tough part for the swap I did on a 99. What I did is to utilize the switch assembly for AQ9, the seat control module for an AR9 seat, and it worked, including lumbar.
I had to change some power, and grounds, as the 99 had NO power, it had a 4 position manual.
As long as you have power, which I am pretty sure you do, you will just have to either chop the harness, which I dont like, or you can purchase the connectors from your local dealer.
Let us know if were can help further, c4c5
Old 11-22-2001, 08:25 AM
CJP63's Avatar
c4c5specialist, Thank you for the valuable information. Carl
Quick Reply: Corvette Sport Seats
