Sponsored by: DashLynx
aftermarket fog lights
Old 09-24-2008, 11:13 PM
slayerized6's Avatar
Default aftermarket fog lights
if i get aftermarket foglights for my t/a, would the pigtails on the new lights match up to the ones on my harness?
Old 09-24-2008, 11:18 PM
SparkyJJO's Avatar
depends on the fog lights
Old 09-24-2008, 11:19 PM
maybe you can point me in the right direction
Old 09-24-2008, 11:44 PM
Brian2006's Avatar
Make sure you get 3157s and you'll be fine
Old 09-25-2008, 12:01 AM
Copy & Paste Moderator
VIP1's Avatar
Bulbs or Housings?
Bulbs: Yes
Housings: No because they typically use different bulbs, but you can make the connection.
Here is how I did mine:
http://www.fadingarrow.com/foglights.htm
(I have a formula, but it should be the same connector.)
That's the turn signal bulb, not the fog light.
Old 09-25-2008, 12:11 AM
i want to find a product where i can just swap the housings and put new bulbs in and power up. I dont care if the bulbs are different, i just want the pigtails to match up.
Old 09-25-2008, 12:16 AM
Brian2006's Avatar
Yeah I'm not paying attention (tired).
You need 880s or 894s. 880s will be straight and 894s will have a 90 degree bent in them.
Old 09-25-2008, 12:21 AM
ok thanks man
Old 09-25-2008, 01:23 PM
VIP1's Avatar
OK.... what is it that you want? ... bulbs or the entire housing?
If you want a new aftermarket housing, its going to be a custom install.
The stock fog light bulbs for the 1998-2002 Firebird are 880.
If you want new/brighter bulbs, technically 880,881,893,894 all fit into the same housing and plug into the same connector. The only difference is the angle of the connector.
880 --- 27.5 Watt, straight connector
881 --- 27.5 Watt, right-angle connector
893 --- 35 Watt, straight connector
894 --- 35 Watt, right-angle connector
You can replace the 880 with a 893 which will be brighter, but it will be hotter and you risk melting the plastic fog light housing. I know from experience. The stock housings also leak and blow bulbs too often to bother with expensive bulbs. Therefore, I replaced my housings with aftermarket units (which use H3 bulbs). Here is my writeup: www.fadingarrow.com/foglights.htm They have been installed since at least the beginning of last year without any issues. The lens is completely clear. The bulb is tinted blue. I don't much care for tinted bulbs but thats what they came with and I'll leave them until they blow. I didn't connect the LED rings.
