How to remove dash from an F-Body
Ok, I'm going to be pulling the dash from my SS soon and replacing it with one from a TA (doors too). I will be completing my sound damping to this area while parts our out.
I've done a search but cant find any instructions (step by step would be nice)on how to remove the dash. I don't have a problem jumping in there and removing things but has anyone done this before? I would like to know what problems i could run into ahead of time if possible.
thanks!
thanks!
There was a write up in the Drag forum.
But there are a ton of 7mm bolts. I started by removing seats and centerconsol for room to move. Then start with the a-pillers, then upper dash cover lifts up(velcro). Then you need to understand that where are two ways the dash is mounted.
1-bolted to car
2- bolted to metal mid structur
I think there is also 8mm, 10mm, and 14mm? also panel popper to release the push in trees on the wiring harness. the biggest size is to drop the sterring column. It is nice to have two people at least at the end when you lift the dash over the wheel as not to damage the leather wheel.
Be carefull on the droping the wheel as it will pull on the wires.
It takes a long time as after removing like 30bolts it seams you always miss a few. The biggest problem you will have as I think you are keeping the HVAC is removing it to sound deadening. AS the firewall is like 60% covered in plastic dash vents. and the hardest bolt is screwed in from the engine bay. And the bolt is behind the motor. Also the hvac has screws from inside and outside.
All I can remember. Hope it helps.
1-bolted to car
ZexGX: i was able to find some good write ups using your HVAC search idea, thanks!
2FAST4U: thanks for your added advice. after searching I found some pictures of a dash removed and noticed there was a lot of plastic covering the firewall so i see what you're talking about. I don't plan on deleting anything behind the dash so I'll have to come up with a game plan if i decide to dampen.
Here's a decent one for anybody thats looking.
https://ls1tech.com/forums/showthrea...t=hvac+removal
thank you both.
thank you both.
