How do I get the high and low beams to stay on at the same time?
Old 10-03-2008, 12:08 PM
miwolverines88's Avatar
Default How do I get the high and low beams to stay on at the same time?
A little while back i saw a post of how to get the low beams to stay on when you switch over to the high beams on your camaro....but im not sure where i found it so if you know how to do it that would be awesome thanks
Old 10-03-2008, 02:04 PM
shock6906's Avatar
My 93 and 97 keep both highs and lows on at the same time. High beams defeat the foglights, however. I don't know if 98+ Camaros are the same way though. Let these guys know what year your car is so they can help you better. Perhaps some basic info in your signature will help out so you don't have to post things like year, make, model, engine, transmission, etc. over and over again with each post.
Old 10-03-2008, 02:25 PM
Copy & Paste Moderator
VIP1's Avatar
Check out the Lighting FAQ:
https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
In there, you'll find how to keep high and low beams on together and how to keep fog lights on with high beams.
Old 10-03-2008, 02:36 PM
2FAST4U's Avatar
Yeah I have my truck set up with 5 sets of HID.
Low dual light
hight dual light
fogs single
when high is on I get 2 lows 2 highs, one low. Stupid bright. But I run relays on all sets. so it is easly jump wire.
Quick Reply: How do I get the high and low beams to stay on at the same time?
