Show off FRC's with which STB?
Which STB shows off the FRC's the best?
I did a search but not much with pictures of both together
Please post pics if you can
Re: Show off FRC's with which STB?
True, Hotchkis looks great as shown by Captain Bling above, ...
But I wouldn't recommend the SLP simply because it's a bit too low & will rub on the FRC's when mounted. (Been there, tried that, ...)
I now have the BMR & it gives about 1/4"-1/2" clearance under it away from the FRC's.
Good Luck!
Good Luck!
Administrator
The Hotchkis bar is my favorite.. bends back out of the way and gives a good place to ancor things like throttle cables and fule lines (too keep them from rubbing the FRC's)
THE example:
THE example:
an example:
an example:
Ok I have one question to ask? Is a STB just a big pain in the *** for when you need to turn a wrench in the engine bay or does it actually provide some enhancement to the car besides looks?
Restricted User
Well it certainly can't hurt. Not to mention it looks cool. The only thing I can say is that when I installed mine, I had no suspension mods whatsoever and it seemed to improve turn-in. It seemed like I could turn instantaneously, as opposed to before the brace when there was a very slight delay between when i turned the wheel and the car reacted.
Could all be psychological. I don't really care truthfully.
