4l80e slip yoke length?
Old 10-15-2008, 05:59 PM
MUSTANGBRKR02's Avatar
Question 4l80e slip yoke length?
I have the slip yoke here and am trying to figure where to cut it at. It is 8.75" roughly total length. From center line to end is about 8.00" I should have about .75-1.00" sticking out the end(i think) So how much should i cut tomorrow at work?
Thanks
Bill
Old 10-15-2008, 06:15 PM
usmc320's Avatar
I would test fit everything before you cut it.
I had about 1.5-2 inches sticking out of the tailshaft with the suspension loaded to give you an idea. It was definitely more than I expected.
Old 10-15-2008, 06:24 PM
30th t/a's Avatar
im also going through this exact situation right now. What are you using to cut the slip yolk with? Mine is 8.125" from the center line of the u joint. I just found out it is too long. It looks like if I cut 1" off, it will work.
Old 10-15-2008, 06:50 PM
I will use the bandsaw at work. I know it is to long already but i am going to pick up the u joint tomorrow and test fit it.
Thanks guys
Quick Reply: 4l80e slip yoke length?
