Which 4L60e will work in my 98 Z28?
Is the 4L60e in the 98-02 LS1 cars the only one that will swap into my 98 Z28? I don't want to make any modifications to the bellhousing, tailshaft, etc. I am wondering if there are any other cars or trucks that have the same tranny. I did a search but didn't find an answer. THANKS.
LS1Tech Sponsor
The 98-2002 t/a and camaro trans is the only direct swap . However the lsx based truck 2wd 98-2006 and the 04-05-06 GTO trans can be used by simply swapping the tail housing (just some bolts an 2 minutes) and the linkage shaft(simple removal of pan a clip and a 15mm nut slide out slide in 10 minutes)
__________________
