new trans installed.. car wont start
it will crank but wont start.. its down at my uncles shop.. he owns a trans shop.. when cranking its pullin code po335 which i believe is the crank sensor circuit malfunction.. a new crank senssor was installed.. still the code..we also installed a new flexplate cuz mine was cracked..there are no pinched wires it was checked 2 times.. there is good fuel pressure .. no pulses on the fuel injectors..thanx
the crank shaft sensor is above the starter i would double check to see that it is plugged in i have seen were people will damage these on simple starter changes it is easy to hit i have also seen people pull the wires out of the conector
Disconnecting the battery will NOT cause a crank sensor re learn, disconnecting the battery with the key left in the on position will.
SteveC
HOGWASH!!!! He would have thrown code P1336, and the vehicle would still start and run, however firing one bank then the other, instead of the correct timing order.
SteveC
SteveC
