A4 to TH400 CROSSMEMBER
Guys, I read all stickys and did a search as well but couldn’t found how to modify my stock A4 CROSSMEMBER to work with Th400 4in tail?!
The only thing I found is this can be done by moving it 2-3" to the back.
Can you please help me to know how to do it, and what I need to do it?
Pics would be much helpful
Thanks in advance
Thanks in advance
one more question..
You used the Spohn solid shim >> http://www.spohn.net/shop/1993-1997-...nting-Kit.html
And poly mount >> http://www.spohn.net/shop/1993-1997-...-Mount-GM.html
am i right in these parts?
Thanks in advance.
Thanks in advance.
one more question..
Thanks in advance.
Thanks in advance.
IMO, eventhogh if i would save there is a big difference in price between them.
Thanks anyway and good luck on your swap
My car was born a 94, so I used a LT1 T56 crossmember. Just order the T56 crossmember for whatever year your car is, there is a difference between the LT1 and LS1 cars. And those are the Spohn products I used, and they were perfect. Although the bolts supplied were the wrong ones, they were easily swapped out. I was able to use a Hurst kit for the third gens, and used the stock torque arm with the TH400. Worked out nice, and it was all a bolt in deal.
The crossmember new from the dealer was like $30 or so.
do you know the part# of T56/LS1 crossmember?
i can not find it anywhere
Yes T56 crossmember can be modified to work. What is the correct angle of the tailshaft? Just have it straight or does it need to be alittle higher than lets say the T56 tail would be?
