trap rpm
trap rpm
dose this look right to you guys
3.73
4l60e lv2 built trans
3500 stall
am traping 6100 on motor mph is at 111-112 running don't know if you need more info
i have hp log files i will post them later
3.73
3500 stall
LS1Tech Sponsor
That would depend on the converter and the STR High STR converters tend to hit hard in the bottom with a loss at the top a low STR converter you might expect a 6% loss +- but the high STR might be considerably more One possible solution might be to lock the converter once in 3rd at the top end eliminating the loss.
__________________
