another FLT Level 3 getting the job done
http://chicagosvt.com/misc/byron1101...ysdad-run2.wmv
01 Z/28
weight reduction :
front sway bar
Welds w/ 195 radials up front and 275/60 radials out back
stock short
our SI5 cam
APE 6.0 heads...got these cheap awhile ago from Z8's ( thanks )
Hooker LT's, ORY , cutout and SLP Dual Dual
SLP lid, K&N and stock MAF
Fast 90 / 90 NW TB ( minor clean up on intake )
FLT Level 3 w/ Yank SS4000
Strange 12 bolt w/ spool and 3.42
TR7 plugs
20 degree's total timing...extra safe
NA
11.31 @ 119 1.53 60ft
NX 150 shot..window switch @ 4100
10.40 @ 129 1.46 60ft
The car still has some left in it as you can see by the 60, but we were slowly working into things by lowering the window switch, but just ran out of time for the day.
01 Z/28
weight reduction :
front sway bar
stock short
our SI5 cam
TR7 plugs
NA
OK Larry, your mission if you accept it, is to make my LT1 turd as fast as your Dads car. You know the rest, limited funds, pushing a stock shortblock, trans and rearend to it's limits. No problem, right?
Leaves smooth.
You guys put a spool in that car...how is it on the street?
How much more can really come off an already impressive 1.46 60' with a full weight car?
With the abuse you guys are successfully throwing at the Level 3 transmission, why would one need to go Level 4/5
Leaves smooth.
The car has been a 1.43 before, so with a bit more foot break and moving the window switch there is for sure more in the 60ft.
I do want to try locking the converter in 3rd for a pass and I'm sure we will see some nice gains. The stall is a little loose on the gun.... I hope Dave doesn't see this
Here's a little something I put together.
The video above should be added soon. Also when you get a chance Larry this will put a smile on your face!
http://www.finishlinetrans.com/projectcars.htm
I just need some official times! Vince
cool
sent you a message
10.97@121 NA for me to date
