SS4000 and 3.90s?
SS4000 and 3.90s?
OK, just oredered my SS4000 stall and did my 3.90s last year and love em. Anybody think this is a bad combo? I think it will be fuggin sweet. I did 3.90s cause everybody dies 3.73s and i did 4000 cause everybody does a 3600, just wanna be different.
gppd ****, cant wait too get back from the sand box and put that stall in next month. Like i said too, for the track, i have a set of M/T ET streets.
^^^^what did you run before the stall, i was hitting 12.74 with my 3.90sonly, and now ill be alot like you, excpet tranny is good so far. Im a heavy *** vert but i sub frams and a bunch of UMI susp. to go in with the stall, so hopefully some 12.3s or better, i want to get as close to 11s before i do the cam-only set up, then later heads and so forth, oh and i have a set of MT ETs on my stock wheels i run at the track, so we will see if the 10 bolt will take the beating or say **** it.
edit, sorry miss-read your post, thought you said you had an str of 2.0, my bust.
I got a POS stall in it now and the best I could muster with it AND 3.91's was a 1.75. I plan to change that very soon.
Your rear should last for a while w/ the auto. Although once you start laying down some good 60's I'd be leary, I had to rebuild my pinion, instead I picked up a used 10 bolt w/ 3.42's, the posi was smoked so then I said screw it and went right to a 12 bolt. Hate dumping $ into a 10 bolt.
