Swapping tranny stuff between two F-body ... Got some questions
OK, here is what I got. My mean street machine is in my sig. It has a M6, but I want to put in a built auto. The outcoming M6 will go into my '02 T/A that has an 4L60E. Here is my plan. I am going to swap stuff like center consoles, shifters, pedal assemblies, wiring harness & etc. For the street machine I am looking at a very well built 4L80E that has all the electronic controls retained. I would like to use the factory computer to control the tranny and lock-up. Are the wiring harnesses hard wired in or do they have quick disconnecting plugs? Are there plug differences between the 4L60E and 4L80E? Anything else I should be aware of when I do this?
I think you are going to have to swap the harness complete. You will have to add some wiring for the input speed senor for the 80 and the pins are a bit different from the 60 to the 80. You can swap the wires in the connector or get a conversion harness from speartech. Your computer will have to be reflashed with a program for a truck program for the 80e transmission. Vince
you need the tune to for segment swapped, lsxtune can also do this for cheaper then hp tuners. You are going to need a slip yoke, dipstick, cooler, u-joint, converter email me for this i know a guy who does them.
https://ls1tech.com/forums/automatic...l80e-swap.html
