TCI Full Reverse Manual Valve Body--- No reverse,1st,2nd,3rd, or 4th now
i installed a new TCI manual valve body into a built 700r4. I have no gears R,1234...the only gear that works is park. shifter shifts through all gears normally without any problems. tci said that my pump is probably bad but I know that there is no way possible that could be it. I thought I installed it right but maybe not, any ideas???
got aggravated, and decided to hang it up for the night. im going to crack it open tomorrow and check the internal linkage. it was running before with some aftermarket shift kit and I left the tranny in the car when I installed the valve body
yea it the c clip that holds the throttle pressure regulator must of not been in all the way cause it was in the bottom of the pan when I droped the pan. all is good now.. tomorrow is my first track day with the new motor combo
