4L60E oil level question
Old 11-20-2008, 01:03 PM
kevtherev's Avatar
Default 4L60E oil level question
So first thing what is the total capacity of a standard box and is the level above the sump gasget line when not running.I seem to be getting leakage out of the wiring connector which I guess would only happen if the oil level was way up there.Strange but it does not happen most of the time,then I notice it's dumped quite abit.
Thanks.
Old 11-20-2008, 01:23 PM
LS1Tech Sponsor
performabuilt's Avatar
Its about 12.5 quarts and yes when the car is not running the level is higher than the plug .
If the plug is leaking you will need to replace the trans internal wiring harness and or the o ring around the plug depending on which ones leaking.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-20-2008, 01:42 PM
kevtherev's Avatar
Thanks for that.My dipstick has been altered and way out.Any idea what the level above say the bottom of sump it should be when running?
Old 11-20-2008, 02:08 PM
LS1Tech Sponsor
I say it should be even with the pan rail when running
__________________
Call 888-744-6542
Old 11-20-2008, 02:17 PM
kevtherev's Avatar
Thanks,great help.
Old 11-20-2008, 03:52 PM
LS1Tech Sponsor
Its what I am here for and your welcome
__________________
Call 888-744-6542
