Built 4L60E and 4L65E Transmission SALE!
https://ls1tech.com/forums/sponsor-s...ines-more.html
XTREME TRANSMISSIONS STREET/STRIP 4L60E UP TO 600 HP
New electronics, Hardened pump rings, Servo D ring kit instead of Teflon rings, New Accumulator Pistons, New Valve Body Spacer Plate, Modified Pump Assembly, Oversized Boost Valve, Transgo Hi-Rev Release Springs, High Quality Overhaul Kit, Frictions and Bushings, Transgo Shift kit, Borg Warner dual cage 29 element Input Sprag, Corvette 2nd gear Servo kit, Wide rear sun gear bushing, Heavy duty sun gear shell "The Beast", High Energy 2-4 Band High Energy 7 friction clutch pack with full thickness Kolene Steels, High RPM Transgo pump slide spring, Teflon Pump Bushing
Usually 1500.00
APF sale price 1395.00
XTREME TRANSMISSIONS PRO-STREET 4L60E /4L65E 600 + HP
New electronics, New Accumulator Pistons, Teflon Pump Bushing, New Valve Body Spacer Plate , Modified Pump Assembly, Oversized Boost Valve, Transgo Hi-Rev Release Springs, High Quality Overhaul Kit, Frictions and Bushings, Transgo Shift kit, Borg Warner dual cage 29 element Input Sprag , Sonnax 4th gear billet servo kit, Billet 2nd gear Servo kit, Wide rear sun gear bushing, Heavy duty sun gear shell "The Beast", Upgraded Bearing Type Reaction Carrier Shaft, Wide High Energy 2-4 Band, 4L65E 5 Pinion OEM Front and Rear Planetary Set, High Energy 7 friction clutch pack with full thickness Kolene Steels, Input drum Steel sleeve prevents input drum breakage at spline area, High RPM Transgo pump slide spring and pump rings.
Usually 1895.00
APF sale price 1775.00
flat rate SHIPPING COST $150.00
Usually 1500.00
Usually 1895.00
I'm running this tranny and I've got to tell you I LOVE IT!! The warranty is tough to beat, and i haven't had a problem yet!
I got mine painted to match my car and they installed a shift kit and baby stall for me. I even had them install it, and the whole process was 2 days!!
My other friend 6litereater (a sponsor on here) also went to them for a tranny on my recommendation, and he's really enjoying his tranny as well!!
I am and LOVE it!!!! I have had a few built trannies before and this is by far the best, no corners cut...
I am running about 400rwhp NA, daily driven, 3200 stall and a 100hp shot of nitrous for fun with NO problems at all.
HIGHLY recommend these guys, they are fellow enthusiasts who've been doing this for awhile, no worries about spending your money here
Also available are Full Race TH-400 & Street Strip TH-350
More details on them here
http://performanceautopartsonline.co...db6d502ee3921e
