Crossmember VS. Torque Arm Relocation Kit "TH400"
Old 11-29-2008, 01:33 PM
SUPER_CHEVY's Avatar
Arrow Crossmember VS. Torque Arm Relocation Kit "TH400"
Just ordered the UMI TH400 crossmember http://www.umiperformance.com/2222?category_id=163 , and would like to know if it worths adding ~70 bucks to get the UMI Torque Arm Relocation Kit+ Torque Arm bushing. http://www.umiperformance.com/2224?category_id=131
I really dont know which one should i get, currently im gonna run the stock torque arm.
Is the crossmember will be just fine from me? or should i replace the order with the Relocation Kit?!
Please help
Old 11-29-2008, 02:41 PM
Guys, I really need your advice urgently!!
Old 11-29-2008, 03:14 PM
squee's Avatar
Your gonna need the torque arm relocation kit (since the torque arm can't mount on the tranny like a stock one) unless your using a tunnel mount torque arm. Might wanna change that order...
Old 11-29-2008, 09:14 PM
Strahley's Avatar
I'd get the second one you posted. I use the BMR version and I love it
If you get a plain crossmember, you'll have to get a bolt-on part to put in the tailshaft, which is like $80. It's smarter to take the torque arm off the trans anyway, and you may as well do it all in one piece
Old 11-30-2008, 12:39 AM
SS DNA's Avatar
Get the one with the Torque Arm relocation !!
Old 11-30-2008, 08:13 AM
UMI Performance's Avatar
Hello,
With the TH400 there is no location to mount the torque arm... so the only way to use a torque arm with the TH400 is to A) Use a torque arm relocation kit seen here- www.umiperformance.com/2213 or B) You wouldn't need a relocation kit if you were running a short tunnel mounted torque arm, but since you are using the factory arm you almost need to go with the relocation kit in order to install the torque arm.
I would recommend to upgrade to the relocation kit part #2213. Also since you are using the factory torque arm you need the new polyurethane bushing part #3004
If I can help anymore please ask and I will be glad too. thank you!
Ryan
Old 11-30-2008, 10:13 AM
Thanks for the help guys,
Just sent BYUNSPEED an email regarding this order. And waiting for their conformation.
