performabuilt convertor reduce trap speed?
Anyone running a performabuilt convertor? if so does it need to be locked in order to achieve or get back your trap speed? I was going 110 then after i put the convertor and tranny in im only getting 105mph in the traps. PCMFORLESS told me that Its possibly because it needs to be locked, so just looking for input or if someone who has ran performabuilt had this problem and what they did to correct it.
It was ordered under Daniel the stall is a 9.5 inch, 3400 stall convertor. Thanks for the quick reply Frank.
BTW just to clarify, In no way shape or form am I complaining about performabuilt, very proud of the service and product I have received, im just not that educated on convertors thats why im asking these questions.
did you have it tuned for the stall? what rpm is it shifting at? hitting rev limiter?
at the top of 1st or 2nd, just going by hptuner logs and watching converter slip and rpm, it looks like my 3600 2.5str is 93.5-94% efficient.
oh.. and how much are you selling the car for?
I was selling the car for 8k if i get that ill let it go, but if not im gonna keep it. I had the car tuned with stock tranny and convertor. only mods it had was full exhaust and lid. Now it just has the addition of a 9.5 inch stall and level 2 tranny. Doesnt bounce rev limiter or nothing like that it was well into the rpm range when it was shifting.
i may just go get it retuned, im talking to a few tuners here today and they are thinking it needs a retune for that stall, becuase with a 1.8 60' they said its not a bad stall convertor and since i tuned with a stock stall this may have thrown it off.
I wouldnt say that just right away.....unless he swapped converters in 10 minutes at the track on the same day he ran 12.9 on the stock stall...to many variables....i think u need to make a few more passes and hope for the same weather/track conditions as u had on ur stock stall pass.
he had a tune before the stall where the tuner probably raised the rev limiter. who knows what his shift points were programmed at that point on the stock stall/tranny.
although he says he wasn't hitting the rev limiter, for sure his auto is shifting way too late.
like he said:that's gotta be worth some sort of loss at the track.
ya he did raise the revlimiter. and when i ran the 12.9 it was june here in Florida so humidity and heat were at the max. When i ran the 12.8 it was 50-60 degrees out from a cold front. I think the final solution is getting the whole thing retuned..the car sounds to healthy to be losing 5mph and that is a big loss so something would be noticable even under everyday driving. so Im gonna fiddle with the computer and see what the tuner can find.
cool man, and i just realized something else and i feel like a dumbass for it, i went from off road x-pipe dumps, to a pacesetter y-pipe, im wondering if that is constricting the top end of the car aswell. But to everyone here thanks for all your support and help.
