video of their TH400 while daily?
If I had a way to take video I would get you some when the weather warms up. Below zero here in central Illinois today. Otherwise a th400 isn't all that bad. I averaged about 11 mpg on the highway on a 28" mt et street radial and 3.73 rear gear in my 12 bolt on a head/ cam car.
When comparing 4th in a T56 to 3rd in the TH400 you have to remember the TH400 is non-lockup, so it's going to actually be a little higher in RPM than your 4th gear is due to the nature of a non-lockup transmission. That being said I'm going to daily drive mine on 26" tall tires and 3.46 gears. I expect 11 or 12 mpg.
whats your rear differentials ratio? and where does your 1st shift at what speed? and where does your second shift?
Damn I was thinking about this transmission, but not anymore, my 4.11 rear end will make this an undrivable car...
Do you know whats the top speed on it?
I have 3.73 gears and I would not reccomend if you daily drive the car about top speed I do not know since my speedo is way off but I hardly ever drive it on the street I will get fix when I go to my tuner in memphis
