assembly lube.
Old 01-30-2009, 09:39 PM
blockheadnic's Avatar
Default assembly lube.
I have looked at all the local autoparts stores, and none of them have trans assembly gel. But i did find there was a engine assembly lube that said it could be used on transmissions. should i try it or are there other options?
Thanks iam assembling my first Th400 so i want to do it right.
Old 01-30-2009, 09:42 PM
Closed ex-Sponsor Account
tptransmission's Avatar
You can get by with using Vaseline if that is all you have. 400s are not particular and require very little to begin with.
Quick Reply: assembly lube.
