4l80e shift kit ? about the check balls
Old 02-01-2009, 12:01 AM
single digit dreamer
parish8's Avatar
Default 4l80e shift kit ? about the check *****
we are puting in the transgo hd2 kit. the instructions show us where to put the "7" check *****. problem is there are 8 in there now. the 8th one that they are not talking about in the directions is right next to the acumulator cover. to make things even more confusing if you look at the crappy pics that came with the instructions it looks like there is a check ball in that location.
do we leave it or get rid of it?
Old 02-01-2009, 12:10 AM
Closed ex-Sponsor Account
tptransmission's Avatar
It is not a big ordeal to leave it out.
Old 02-01-2009, 12:11 AM
jakeshoe's Avatar
I'm pretty sure you are talking about the location that doesn't get a checkballs, even on a stock rebuild ATSG says remove it.
Let me see what I can come up with to get us on the same page...
Old 02-01-2009, 12:22 AM
FLT
FLT's Avatar
With that kit they have you leave 1 ball out. It is the one by the front band servo. There is one other location in the case very close to this position that in early models had a ball as well. Do not install a ball in either location. Follow the directions and you will be fine. Vince
Old 02-01-2009, 12:24 AM
parish8's Avatar
thanks for the quick reply. since i got you guys on here i got another one.
the last page of the instructions is for upgrades "if the trans is apart". we are a little leary of taking the front of the tranny apart but it is out and on the bench so we could.
what do those springs in the direct clutch drum do? is it worth taking the tranny apart to do this mod? also shows drilling a hole in the pump stator, drilling a larger hole near the front seal and lastly puting in a new intermediate snap ring.
i didn't do any of that internal stuff in my truck and got into the mid 10's at 5000lbs. how important are those last few "internal" steps?
Old 02-01-2009, 12:28 AM
Your signature says you have a FLT 4l80 in there already, Aren't those mods in there already?
Old 02-01-2009, 12:31 AM
FLT
FLT's Avatar
They are good upgrades to add with the kit. If you do not feel comfortable doing them then save the parts for when the trans is built.They are not required. Vince
Old 02-01-2009, 12:32 AM
jakeshoe's Avatar
Don't drill the hole in the pump stator.
The drainback hole for the seal, I've never seen one blow on a 4L80E, so I don't do that either.
The HD direct return springs are to prevent centrifugal apply of the directs. If this is a sub 6000 rpm combo, don't worry about it. I usually drill a bleed in the drum in lieu of the springs.
The snap ring is good practice but if you don't set the 1-2 shift to kill, it should be fine without it.
Old 02-01-2009, 12:37 AM
FLT
FLT's Avatar
Different project.
+1 on not drilling the large holes in the pump. Not needed. The small .040-.050 hole for full time lube is ok to do.
parish8's Avatar
these mods are for our nova wagon project. trying to get by cheap this year. see if we can really toast it before sending it off to vince
btw we got the car fired up and running on the squirt yesterday. converter from circle D was shiped on friday. tranny should be in the car next weekend. driveshaft a week after that. wont be long now
Old 02-01-2009, 12:40 AM
FLT
FLT's Avatar
Circle D converter......Huum how did you find them? LOL JFWY Good to hear and I would like some video's!
Old 02-01-2009, 12:42 AM
jakeshoe's Avatar
Originally Posted by Vince @ FLT
Different project.
I only do the full time lube on towing applications, not hotrods.
Maybe not an issue with the 80, but you guys know the converter charge pressure issues with the 400s and how that mod can make it worse.
Old 02-01-2009, 12:43 AM
parish8's Avatar
we are going to use a squirt to run the tranny, this should be fun.
Old 02-01-2009, 12:48 AM
jakeshoe's Avatar
Let me know how the MS works for the trans, last time I was researching it, they were still working on it.
We've been using the PCS controllers.
Old 02-01-2009, 12:49 AM
FLT
FLT's Avatar
I did not know that could be done. Is the Diesel Geek helping you with this one?
Old 02-01-2009, 12:55 AM
parish8's Avatar
that pic of the instructions if funny. it is almost the exact same page but ours doesn't mention leaving that ball out and also doesn't say where that washer goes for the "new 4th bolt". i wonder if out kit has been sitting on the shelf for awhile.
Old 02-01-2009, 12:56 AM
jakeshoe's Avatar
No,
You have the newer kit with the seperator plate right?
These instructions are for the old HD2 kit, I had to resurrect a computer to find them on an old hard drive.
Old 02-01-2009, 12:58 AM
parish8's Avatar
geek has been over here a little but mostly it is the new super geek doing all the computer stuff, you know John the fairmont driver. he is doing all kinds of crazy stuff. touch screens, can bus, phased fueling, multi speed fans and fuel pumps... a bunch of other stuff that i over my head.
Old 02-01-2009, 12:59 AM
parish8's Avatar
No,
yep, our kit came with a seperator plate. we are doing the vacume modulator too.
Old 02-01-2009, 01:02 AM
hawkls7's Avatar
sorry to ask but i did do that , will it cause issues ?
Quick Reply: 4l80e shift kit ? about the check balls
