stall or trans bad
Old 03-06-2009, 08:47 AM
98z8uup's Avatar
Default stall or trans bad
I am haveing a hard time trying to find out which is bad. I have a stock stall with a 4l60e trans. The shift good but sometime when I jump on it. It will not pulled until I take my foot off the gas, then it will make a noise then it will pull. It does this sometimes. It does this at low or high speeds.
Old 03-06-2009, 10:28 AM
dondb's Avatar
Sounds like it could be either? I think the only way you can really tell is if you take out the Trans. for inspection. Maybe one of the sponsers will be of more help!
Old 03-06-2009, 06:12 PM
98z8uup's Avatar
Thanks I may end up getting a new trans and stall from one of the sponsers.
Old 03-06-2009, 06:31 PM
Closed ex-Sponsor Account
tptransmission's Avatar
First check the basic like fluid level and condition of the oil (burnt etc). Then check to see if there are any codes.
Old 03-06-2009, 08:25 PM
9000th01ss's Avatar
It's the transmission. At this point the converter and cooler are probably full of garbage. I'd start by dropping the pan and looking for metal and other trash.
Old 03-06-2009, 08:57 PM
LS1Tech Sponsor
performabuilt's Avatar
I would agree on pulling the pan to see whats in there but it does sound like you are in need of a trans and converter
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-06-2009, 09:26 PM
98z8uup's Avatar
Thanks, the tran s has a lot of miles on it. So I will be looking into getting one real soon.
Old 03-07-2009, 12:14 AM
LS1nut377's Avatar
ya that what i would start doing is preparing for a tranny swap. good luck. i know im going to need one in the next year or so....
