Car wont shift out of 1st at WOT
Old 03-17-2009, 12:29 PM
onebadazzls1ta's Avatar
Default Car wont shift out of 1st at WOT
Shift settings are set at 45 in 1st gear I have to let off in order to get it to shift. I have a stock 4l60e shift kit 4:10 gears drop in and a tuner.
Old 03-17-2009, 12:57 PM
LS1Tech Sponsor
performabuilt's Avatar
What about the rpm settings?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-17-2009, 01:14 PM
5600 i believe
Old 03-17-2009, 01:18 PM
Gingervitis Addict
slow67's Avatar
If you are using stock tire size, I would try something more like 33 mph.
Old 03-17-2009, 01:41 PM
245/50r16
Old 03-17-2009, 02:22 PM
Badazz 97 TA's Avatar
is it even possible to shift at 45 in 1st gear w/ 2.73's let alone 4.10's with stock wheels? !!!
Old 03-17-2009, 03:52 PM
I didnt have this problem untill I put the shift kit in. so what I should shorten or lengthen the shift points?
Old 03-17-2009, 03:54 PM
it shifts fine under normal throttle just not at WOT.
Old 03-20-2009, 06:04 PM
antsls1's Avatar
my tranny was doing the same thing it just banged off the rev limiter in WOT in first right. i wound up having to replace the tranny all together.bcause it onlygets worse
Old 03-21-2009, 11:54 AM
LOL that's not something I wanted to hear LMAO. So what it'll eventually find it's way into 2nd and 3rd?
Old 03-21-2009, 12:26 PM
LS1 Sounds's Avatar
45mph in 1st gear with a 4L60E, that tire size, and 4.10s would put you around 7,500 RPM, so no I would not expect it to shift. You need to drop your shift MPH setting to something closer to 33-35mph and then tune using RPMs.
Old 03-21-2009, 12:28 PM
LS1 Sounds's Avatar
Yes, all other things being equal in this thread he would be running 55 mph at 6,000rpm with the 2.73s.
Old 03-21-2009, 04:54 PM
02_ramair_ta's Avatar
I suggest something around 34mph, and 5900 rpms.. Also bump up shift pressure "make it firm" not too much, but with a converter, i have found that you need to have alittle more pressure build up, to make it shift earlier.
hope it helps Also make sure your part throttle/W0T shifts match at 100%..
Old 03-22-2009, 01:02 PM
ok are you using a predator too?
Old 03-24-2009, 06:00 PM
ok i changed the shift point in 1st gear to 35 at 5900 rpm's what now? I kinda messed with the 2nd gear shift point but I dont know how the cars gonna react
Old 03-24-2009, 06:11 PM
ok she still doesnt wanna shift out I have to let off so it changes from the 1-2 I also bumped the rev limiter quite a ways up
Old 03-24-2009, 09:53 PM
antsls1's Avatar
i am still sorry to say it but you are gonna have to replace the tranny. i was having the same exact probs man. performabuilt trans will tell you the same thing. i know somebody that can get you a rebuilt tranny for 700.00 with a transtar or daaco torque converter plus shipping if ur interested. that is who i had do mine and it is excellent now. pm me for more details.
Old 05-02-2009, 06:05 AM
I use Hp tuners, I have never seen or used a handheld, like that, but if the shift tables dont match, you will not shift, I hope that helps, at the least take it to a shop that can tune it for you, if your lost...
Old 05-11-2009, 12:27 AM
pontiac_boy's Avatar
What exactly was wrong with yours? Mine daily drives fine, Infact the only time i have a problem is when im at WOT. When im at WOT it wont shift until i let all the way off and rpms go down to 5700 or so.
Old 05-12-2009, 08:43 PM
Blk_Ws6's Avatar
mines was doing that to it was the vss sensor an the tps sensor went bad.
Quick Reply: Car wont shift out of 1st at WOT
