Flexplate & Cooler Install Questions!!!
Been searching can't find anything I just picked up a SFI Flexplate
Didn't come with any new hardware my question is should I re-use my stock bolts???
Also does any body know what the torque spec are for the flexplate bolts?
And is there any sequence to follow?
On the transmission cooler should I run it inline to the factory cooler in the radiator or just remove the lines from the radiator and use only the aftermarket cooler???
If I remove the lines should I plug the radiator with NPT fittings or leave them empty!!?!?
Thanks so much in advanced!!!
Location: Your girl's back door giving her the long stroke while you're at work
http://www.texasfbody.org/TorqueSpecs/
I torqued mine the same way as a wheel
Can't help ya on the cooler, I'm running a TH350 and a stand alone cooler
