TH350 and B&M Pro Ratchet
Old 03-19-2009, 11:17 AM
CB99SS's Avatar
Question TH350 and B&M Pro Ratchet
I've got a TH350 RMVB with a B&M Ratchet Shifter. Right now I have to pull the shifter back twice to go into reverse. Then N,1,2,3. Is there a way to adjust or set up the shifter to be pulled once for reverse?
Thanks
Chris
Old 03-19-2009, 11:39 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Mine is the same way
Old 03-19-2009, 03:24 PM
forcd ind's Avatar
thats the way it is-in GM cars its that way, the shifter is designed for a bunch of diff manfs. cars-even using it for a 4 sp GM its the same way
its because of the distance from park to rev i think
