4l80e swap..Driveline
Old 03-20-2009, 01:41 PM
salemetro's Avatar
Default 4l80e swap..Driveline
I'm rebuilding a 4l80e for a swap (until I can afford a FLT unit), and am just curious if anyone knows of a driveline that might be a direct bolt-in for my 96 firebird.
Thanks.
Old 03-20-2009, 03:25 PM
Gingervitis Addict
slow67's Avatar
The 4L60E in F bodies and the 4L80E are the same length. You can use the stock driveshaft (with a conversion U joint and a new transmission slip yoke).
Make sure its a later model LS1 4L60E driveshaft....I think the older trannies are shorter.
Old 03-21-2009, 11:29 PM
Bersaglieri's Avatar
I know the LT1 4L60e's are shorter, not sure on LS1's. Dont know the original posters engine.
-Dustin-
Old 03-22-2009, 07:54 PM
Gingervitis Addict
slow67's Avatar
i reused my driveshaft in my swap.
Old 03-22-2009, 08:16 PM
MUSTANGBRKR02's Avatar
Only problem with the 96 is the standalone controller or going FMVB. The LS1 D/s is the same length i just had to swap the u joint.
Old 03-24-2009, 01:22 AM
salemetro's Avatar
Trans is from a 00 2500 expressvan, and I'm having the converter built to match the flexplate of the ffi lq4/l92 that I'm building for the swap. All of the vehicle wiring and ecu is being swapped to 2000 f-body, so my understanding is that the ecu should control the 4l80e without any problems other than a trans-harness modification and a few re-pins at the ecu......does this sound correct??
Old 03-24-2009, 08:57 AM
Gingervitis Addict
slow67's Avatar
Yep. I am controlling my 4L80 with my 2000 computer.
Old 03-24-2009, 10:01 AM
Lafngas's Avatar
Who made the ECM programming change, and what did it entail????
Old 03-24-2009, 10:26 AM
Restricted User
1BAD_LS1's Avatar
Subscribing......
How does the stock 4L80 compare to a built 4l60???? I might go this route if its cheaper and easy!
Old 03-24-2009, 12:32 PM
Gingervitis Addict
slow67's Avatar
I already had HPtuners. I sent my tune to support@hptuners.com, and a few days later, I had an email back with the tranny segment swapped. I did a write entire, and I was done.
A stock 4L80E should be good to 500-600rwhp stock, maybe more if the RPMs are kept down. Parish8 made into the 10s in a pickup with a stock one. If you do keep it stock, I recommend the Transgo shift kit that dual feeds the direct drum, it helps out with strength a lot.
Old 03-25-2009, 06:36 PM
blueflamespl's Avatar
Does anyone know if I can use my stock M6 drive shaft on a 4l80E swap with the stock rear (swaping yokes), In other words, will the length work?
Kurt
Old 03-25-2009, 07:24 PM
yes length should be fine same as a A4 i believe.
Old 03-25-2009, 08:31 PM
Thanks.
Cool, that should let me get this up and running with the stock rear until I can afford a midwest 9".
Old 03-25-2009, 10:07 PM
Gingervitis Addict
slow67's Avatar
Originally Posted by blueflamespl
Thanks.
Same here. Stock d/s 10 bolt.
Old 03-25-2009, 11:27 PM
ShevrolayZ28's Avatar
Kurt
you should check the length. the slip yoke should be 3/4-1" from bottoming out on the output shaft with the suspension fully loaded. If it's too long or too short you could do some damage.
On my car the stock DS is a tad shorter than I'd like it to be but figure it'll be ok for a test ride or two. This is with a Strange U1650 yoke.
Old 03-26-2009, 07:59 AM
Gingervitis Addict
slow67's Avatar
My 4L80 has a fully splined output shaft, so I got the 7" yoke, so the little extra that sticks out is ok for me.
Old 03-26-2009, 10:43 AM
chevyz2801's Avatar
i have a question, i have the yoke that was originally in the tranny and going to get a conversion u-jount, but the yoke will go in 3/4 than will stop but you can push it all the way in with little force but will pop out when you let go to me it seems like it is building up air pressure inside the yoke. The yoke doesn't have a hole in the end to let out air.
Old 03-26-2009, 11:12 AM
7" from center of u-joint to center of u-joint? Or 7" overall? The one I am using is 5.5" from center to center.
Old 03-26-2009, 11:25 AM
Gingervitis Addict
slow67's Avatar
It is an O-ring inside the tailhousing. Do yourself a favor, and get an aftermarket yoke. Some people have had a VERY difficult time finding a conversion yoke for the stock 4L80 one. Its some wierd oddball one.
When you do switch yokes, put a regular (non-booted) rear seal on it, and take off the O ring (it is inside a pressed on sleeve on the tailshaft).
Old 03-26-2009, 09:07 PM
chevyz2801's Avatar
do you know any of the part # i will need and thanks
Quick Reply: 4l80e swap..Driveline
