OD lockup hits pretty hard?
i have noticed that when my car locks up in OD it hits pretty hard. its not like hard such that something is broken. it just feels like a very firm shift. i have a performabuilt tranny with a yank PT3800 stall. it very well may be a tuning issue but we could not seem to fix it. any suggestions?
LS1Tech Sponsor
Actually we disable PWM and make other mods to improve lockup clutch engagement, It should indeed feel almost like a firm gear shift and will be more notable with high stalls locking at lower speeds. The lockup clutch in the trans is like any clutch reducing apply slippage will increase its life.
__________________
LS1Tech Sponsor
Well a 3800 stall is a high and your locked rpm at that speed would be quite low where unlocked the rpm would be hovering at 3200 or so in 4th so it would would be a considerable drop and I imagine a little agressive feeling sorta like slipping the clutch on a manual then suddenly popping it.
Should be fine as far as not hurting anything. Raising the LOCKUP speed would put the unlocked to locked RPM closer and make it much less noticable however.
__________________
I have just over 1000 on my converter and the lock up is getting less brutal. I think it just needs to break in.
