perm. trans pressure gauge
Old 03-29-2009, 06:52 AM
forcd ind's Avatar
Default perm. trans pressure gauge
i was going to install a permanet trans pressure gauge in the car, was wondering if thats a bad idea based on the high pressure they see, and i couldnt find an Autometer gauge that high anyway
i have a test gauge i used, but kind of a PITA with it wraped around everything while driving, lol
Old 03-29-2009, 07:58 AM
NastyC6's Avatar
i do it to tune it in,most shops set pressures on the dyno,300-320 is max press.,finding a nice small gauge might be a problem,......
Old 03-29-2009, 11:23 AM
LS1Tech Sponsor
performabuilt's Avatar
There is a compnay that makes a nice digital guage. Just cant remember who .
And I hope no ones setting a 4l60e to run over 300 psi how about 225 + - as a max.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-29-2009, 11:31 AM
FLT
FLT's Avatar
The only time it would be even close to that is in reverse at WOT. I guess with a trans brake it is possible. I have never seen anyone ever monitor transmission line pressure in street car. I have talked to a serious player that they do monitor pressure in a 2000rwhp glide. But then again that is a serious race car! Vince
Old 03-29-2009, 11:54 AM
LS1Tech Sponsor
Yes I think the highest I have ever seen in was like 285 but that one had a sticking PR valve.
__________________
Call 888-744-6542
Old 03-29-2009, 01:11 PM
9000th01ss's Avatar
Thats all you guys have seen?
When I got my used 60,000 mile 4L80E with no reverse I seen 550psi in reverse at under 3000 rpm. The only problem it caused was a hairline crack in the rev servo. And I guess that might be why the bushings were worn real bad. The clutches were nice, I guess they were holding tight
Old 03-29-2009, 01:23 PM
9000th01ss's Avatar
Heres two from Summit. VDO Gauges. Up to 400 psi.
http://store.summitracing.com/partde...5&autoview=sku
Hope the links work.
Old 03-29-2009, 01:24 PM
FLT
FLT's Avatar
I have seen where problems with a trans will exceed that that but not with one that is in good working order. I made a mistake on a FMX with installing a PR spring backwards once and that thing pegged a gauge hard when we fired it up on the dyno. IIRC it was a 600psi gauge! Whoops!
Old 03-29-2009, 01:40 PM
LS1Tech Sponsor
I have seen a 4R100 run over 400 PSI Blew the hose apart on the gauge I got a tranny fluid bath.
Guys complaint was it went into gear to hard , I wonder why lol.
__________________
Call 888-744-6542
Old 03-29-2009, 09:03 PM
9000th01ss's Avatar
I'm an HVAC guy, I use refrigerant charging hoses---900 PSI working pressure. 3500 PSI burst pressure.
Getting sprayed with refrigerant/oil thats 40 to 60 below zero isn't much fun either. Not to mention if you're on the high side of the system.
Old 03-29-2009, 09:56 PM
Randy WS6's Avatar
I Use stainless steel braided nitrous line, It good for 3000psi
Old 04-01-2009, 06:45 PM
PedaltoMetal's Avatar
Built for offroad use but still a good read.http://www.4wheeloffroad.com/techart...ion/index.html
