B&M tranny cooler install
Old 03-31-2009, 01:46 AM
LCplmarine98's Avatar
Question B&M tranny cooler install
Anybody know if the B&M tranny coolers are a direct replacement for the sock one or do they require new fittings and brackets to mount? All the sites i have looked at for buying one dont explain it.
Old 03-31-2009, 10:50 AM
PontiacFan's Avatar
An aftermarket transmission cooler is typically mounted after the stock unit, which is in the radiator.
For all I know, there would be no 'direct replacement'.
Old 03-31-2009, 01:12 PM
RooRnZ28's Avatar
I have a B&M with a fan, and my mechanic had to make a bracket in order to properly mount it. I'm sure with any cooler, some sort of strong mounting support will be needed.
Old 03-31-2009, 06:49 PM
01ssreda4's Avatar
if you get the B and M cooler with the installation kit then it will come with everything you need....
Old 03-31-2009, 08:11 PM
I have never seen an install kit. Any idea who sells one?
Old 03-31-2009, 10:03 PM
01ssreda4's Avatar
no its not an install kit, its a cooler with fittings hoses clamps and **** and its slightly more expensive then just the cooler.
Old 03-31-2009, 10:04 PM
01ssreda4's Avatar
here ya go
http://store.summitracing.com/partde...5&autoview=sku
Old 03-31-2009, 10:11 PM
Cool thanks
Old 04-01-2009, 11:00 AM
12secSS's Avatar
That is the one I always recommend! If you need help installing it, let me know as I have installed several of these things.
