Help my ID Transbrake manufacturer
Old 04-18-2009, 04:07 PM
rickou812's Avatar
Default Help my ID Transbrake manufacturer
Can some one tell me how to identify the manufacturer /builder of a trans-brake VB.
I bought a used TH350 with a transbrake, and I need to rebuild the tranny, but need to know who built the transbrake so I know what modifications needs to be performed. It seems every builder has there on instructions and they are all different.
Thanks,
Rick
Old 04-18-2009, 05:11 PM
chris718's Avatar
post pics of the vbody and plate.
Old 04-18-2009, 05:20 PM
FLT
FLT's Avatar
Old 04-18-2009, 05:37 PM
rickou812's Avatar
OK, give me a minute, but it is a GM valve body, figured they all look the same..
Just need to know if the stamp them some where in order to ID them.
Let me try to get some pics, but be warned my camera sucks as*..
Old 04-18-2009, 05:49 PM
FLT
FLT's Avatar
Get some pictures of the valve body plate and also the brake solenoid. Vince
Old 04-18-2009, 05:56 PM
rickou812's Avatar
I didn't get any of the silenoid, I already went and took these though.
Old 04-18-2009, 07:56 PM
WE TODD DID's Avatar
What is stamped on the filter boss? Looks like it may say JW, although that looks like a homemade separator plate.
Old 04-18-2009, 08:29 PM
FLT
FLT's Avatar
+1 on that info^^^^^ If it says JW.....I think we have a winner. Looks like a good piece if I had to guess. The separator plate I'm sure is apart of the kit. I have a few Coan pieces at the shop I will have to match them up to this valve body to see if it is the same. Vince
Old 04-18-2009, 10:06 PM
jakeshoe's Avatar
Yeah,
Coan usually uses an aluminum sep plate. TCI usually has a gold plate.
Old 04-18-2009, 10:07 PM
Originally Posted by jakeshoe
Yeah,
I've seen red ones too.
Old 04-19-2009, 12:18 AM
chris718's Avatar
That is a copy of all the other 350 stuff out there,EXCLUDING mine.Ill give you a tip,though.Block the hi feed at the case where it goes into the reverse side of the case at the pump face or youll have a real long 2/3 upshift.
Old 04-19-2009, 12:51 AM
rickou812's Avatar
I was told this transmission had a TCI transbrake, but I had suspicions. When I pulled it I noticed the JW stamped on the filter boss along with some other numbers and then started to wonder if it was indeed a JW..
So chris do you suspect it is a copy of a JW brake?
Old 04-19-2009, 09:19 AM
FLT
FLT's Avatar
I have never had to do that and never have had that issue. Then again we always use the Coan products because they work well for us. I'm actually doing one here probably this week with a reverse pattern brake. I will pay close attention to it on the dyno. I know you believe in your products but all these other companies can't possibly have this issue with every valve body they make. Vince
Being that it has JW stamped on it I would have to think it comes from JW. Why would TCI sell a product and put the JW on it? I think you got some bad info on the manufacture of the brake. I would contact JW with the info you have with the markings. I bet that the numbers have to do with a serial number or a production date. Vince
Old 04-19-2009, 10:29 AM
jakeshoe's Avatar
JW makes good stuff, so there is not an issue with using that VB. IMO JW stuff is probably in general better quality than TCI.
I think Chris is talking about the seperatore plate. It looks like it still has a reverse orifice in the plate.
When you do the dual feed to the drum, in 3rd gear it backfeeds the fluid through the reverse passage, through the plate, it pisses it out at the manual valve. This plate appears to still have the hole that allows it to **** out. It's a very small hole but will cause some fluid loss. It may be left there to allow air to bleed out quicker in the case of a drum not being drilled.
I prefer to block the hole in the case anyway because it requires less fluid to fill the circuit on the 2-3 shift, and the drum should be drilled anyway to prevent high rpm 1st gear centrifugal apply of the directs.
Old 04-19-2009, 10:44 AM
rickou812's Avatar
What about the Lo/reverse piston, JW says to drill a 1/16 hole in it, but so far they are the only one that do this. Why do they recommend drilling it?
And where is the hole you guys are talking about plugging?
Thanks
Old 04-19-2009, 11:00 AM
rickou812's Avatar
Also what are you doing to keep the sunshell ring in place? Is there spiral locks for these?
Thanks
Old 04-19-2009, 05:20 PM
jakeshoe's Avatar
Thanks
Drilling a hole in the L/R piston allows faster release on a manual 1-2 shift.
Snap rings can be tack welded in high rpm applications.
Old 04-19-2009, 05:25 PM
rickou812's Avatar
Thanks, why is JW the only manufacturer that recommends drilling the L/R piston? Is this mod compatible with all brake apps?
Old 04-19-2009, 06:25 PM
rickou812's Avatar
The numbers that are stamped into the filter boss are:
50 00641
M
D08
JW
Not sure what they mean, they do not seem to correlate with the JW part number: 20550BR
Quick Reply: Help my ID Transbrake manufacturer
