On a trans swap (98) camaro is what this is in referance to from automatic to stick car dont see anything mentioned about the programing setup does anyone have a link manly on the VSS setup a. A pm would be great
The vss reluctor in an A4 and in the M6 are totally different. You will need to have your computer reflashed with a program for the A4. Also I'm sure that the rear ratio and tire size will need to be entered. Vince
