Is my trans going out?
Old 04-21-2009, 10:34 AM
bigboy t/a's Avatar
Default Is my trans going out?
Ok i got a 99 t/a and sometimes the tranny when i am just cruising around the city it stays stuck in 2nd gear and doesnt want to upshift unless i play with the gas a little. And sometimes on the highway when i gun it from around 60mph the rpms go up when it downshifts but the car slowly picks up speed and sometimes the trans is perfect. i think my clutches are burnt but i could be wrong. so can anyone help me or give me suggestions on what to do.
Old 04-21-2009, 12:12 PM
LS1Tech Sponsor
performabuilt's Avatar
IDK sounds more like a tuning or sensor issue, Generally when a trans is bad or the clutches are bad the trans will free rev likle neutral when you floor . And its generally not ramdom its either good or bad .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-22-2009, 02:27 PM
bigboy t/a's Avatar
Ok thanks guess its probably going to be a sensor issue again because someone has already been in the trans to replace the sensors a while back. Probably cant be the tune on my car cause i dont have a tune.
Old 04-22-2009, 03:14 PM
hevymetalg's Avatar
Does the trans have a shift kit?
Old 04-22-2009, 08:00 PM
LS1_K1DD's Avatar
VSS Sensor? Sounds like a problem i had. about $23 from a local Napa auto parts store and about 5 seconds to put in.
Old 04-23-2009, 10:34 AM
bigboy t/a's Avatar
no it doesnt have a shift kit; kind of wish it did sometimes
never thought about that, may try replacing that. thanks for the input
Old 04-23-2009, 08:29 PM
LS1_K1DD's Avatar
No problem. After i replaced it my car ran fantastic. Hope it works out man.
